Split level floor plan
Strumentazione, rivestimenti, cruscotti, sedili e quant'altro
Messaggioda jennermack » 04/05/2018, 8:53
Hi,
This software appears to be designed for standard floor plans. How well doe it handle a split level floor plan?
The "main" center section of our home is two stories with a gable roof facing front to rear. The walls on each story are about 8 ft. To the left and right off the main section are one and two stories each with gable roofs facing left to right. Inside the home the right 1st story is -5 ft in elevation and has a cathedral ceiling
Is it possible to build that sort of floor plan using Live Interior? I've experimented with trials from other apps but they all suffer the same limitation - none of them can accommodate split level designs. As soon as we change story heights on the left and right sections, it affects the main section as well. And there's no way to make the left or right "stories" a few feet higher than the main section ground floor.
We need an application that would allow us to build and roof the main, left and right sections independently, yet still connect and finish them internally.
Any help will be apprecited.
I didn't find the right solution from the Internet.
References:
http://www.belightsoft.com/forum/viewtopic.php?t=11001
Workforce Solution Marketing
Thank you.
jennermack
Torna a Interni
Visitano il forum: Nessuno e 2 ospiti
